Hi there,
I have setup up all the connection for T6963C and now I would like to know how to initialize the display and display bitmaps?I got confused with DATASHEET provided.
Please help...
Walter.
How to initialize T6963C LCD Display
Hi Walter,
I took a look at that datasheet ~ http://home.comet.bg/datasheets/LCD%20Grafical/T6963c.pdf
And it isn't very friendly, although all the details are there.
Here is an example of someone else who got it to work:
http://www.rayslogic.com/propeller/3rdPartyHardware/3rdPartyHardware.htm
and toshiba's application note which explains better than the datasheet how to initialize and use the command/font system:
http://www.sparkfun.com/datasheets/LCD/Monochrome/AN-029-Toshiba_T6963C.pdf
Hopefully these help and you haven't already looked through them. I haven't used the T6963C myself, but I assume they're similar to the standard 16x2 LCD screen interfaces. Which are difficult to get working in the beginning and easier to use later on.
Hi PyroElectro,
Thanks for your information. But, I have a few questions need to ask you, hope that I didnt give you much problem...
Now,
I have connected all the pins, see below,
Input , Output to T6963C
FGND -> VSS
VSS -> VSS
VDD -> VDD
NC
WR -> WR
RD -> RD
CE -> CE
C/D -> CE
NC
RESET -> RESET
D0...D07 - > D0..D7
FS1 -> FS1
NC
NC
NC
and
I have read through the code from "Display Datasheet" from the weblink you gave to me,I noticed that there are the set of pins defination i.e. DAT, CDAT1, CDAT2, COM, CLR1 CLR2, DL1, DL2 and DL3 and I have no idea where those pins from. Accroding to the example code from "Display Datasheet", I need to do initialization to those pins. If based upon connections as above, it is possible to perform LCD initialization or I need those pins (CDAT. CDAT1 & etc) to perform initialization?
LEt's say, those pins(CDAT, CDAT1 & etc) are not required, which pins I need to use for intialization based upon my connection?
Many Thanks!
Walter.
Now,
FGND -> VSS
VSS -> VSS
VDD -> VDD
NC
WR -> WR
RD -> RD
CE -> CE
C/D -> CE
NC
RESET -> RESET
D0...D07 - > D0..D7
FS1 -> FS1
NC
NC
NC
and
Many Thanks!
Walter.
Re: How to initialize T6963C LCD Display
I have setup up all the connection for T6963C and now I would like to know how to initialize the display and display bitmaps???????
_____________
== http://www.solitairecardgame.info/ ==
_____________
