#10 VHDL vs Verilog vs Schematic [Post Homework Here]
Postby ThePyroElectro » Thu Aug 28, 2014 7:25 pm
http://www.pyroelectro.com/edu/fpga/vhdl_verilog_schematic/
Re: #10 VHDL vs Verilog vs Schematic [Post Homework Here]
Postby Bingo600 » Thu Sep 04, 2014 6:26 pm
Chris i'm a bit late :oops:
But my vacation is finish , and i was hit hard at work.
Well here is my homework
Which design methodology (Verilog / VHDL / Schematic) is best suited for a large scale
project? Why?
1: Schematic entry is cumbersome to change if large changes has to be made.
   Consider a latch has to be changed from 16 to 32 bit's , that's a lot of wires to redraw.
2: This is where the HDL has it's advantages.
   But i will not go into a VHDL vs. Verilog war.
   Instictively i would go for Verilog because i have a C background.
   But i will continue to use VHDL , primarily because it forced me to drop the "C" (sequential) thinking.
   But also because VHDL seems to be the chosen language here in Europe.
Use the schematic – block diagram design method to make a simple design of your choice.
Simple but time consuming 8)
See attached zip
I have made a 1Hz blink led on my EPM240 board ,witch have a 50Mhz Clock
So i'll use 4 x HC390 dividers in a divide : 100 / 100 / 100 / 50 configuration.
It took a very long time compared with what i would have used in VHDL
It won't fit in the EPM3032 as it uses 39 Cells , but that's not a problem with my EPM240
Flow Status   Successful - Thu Sep  4 19:54:19 2014
Quartus II 64-Bit Version   13.0.1 Build 232 06/12/2013 SP 1 SJ Web Edition
Revision Name   lesson10d
Top-level Entity Name   lesson10d
Family   MAX II
Device   EPM240T100C5
Timing Models   Final
Total logic elements   39 / 240 ( 16 % )
Total pins   3 / 80 ( 4 % )
Total virtual pins   0
UFM blocks   0 / 1 ( 0 % )
To small to really see , and the PDF is larger than 256k , so i can't upload a decent print of the schematic
After getting a sneak peak at Verilog, VHDL and Schematic. Which method of building a
CPLD/FPGA image do you like the most? Why?
I like Verilog the most , but will use VHDL.
I will try not to use Schematic , as i need the VHDL training .....
Afterthought:
Well after havng tried the schematic for the 50.000.000 divider ,
i'm positive that i won't use the schematic for anything but
simple combinatoric logic. If i'll ever use it again.
Edit:
Btw. Why don't CPLD's have pullup/pulldown's like the FPGA's :?
I actually had to connect RESET to GND before my EPM240 would blink at 1Hz
lesson10d-quartus-project.zip
(45.85 KiB) Downloaded 534 times
lesson10d-RTL.pdf.zip
I still can't attach PDF files , so i have to zip them.
(52.4 KiB) Downloaded 507 times
Postby ThePyroElectro » Sun Nov 02, 2014 11:52 pm
Bingo600 wrote:Chris i'm a bit late :oops:
project? Why?
See attached zip
Family   MAX II
Device   EPM240T100C5
Timing Models   Final
Afterthought:
Edit:
I apologize for my delay as well in responding!
Thanks for attaching your design again. Your homework answers are all correct!
It was a pleasure to help you out throughout this course. Don't let the VHDL vs. Verilog debate steer you 100% in either direction. Xilinx and Altera are actually moving into a direction where both VHDL and Verilog files are used inter-mixed in designs and actually their top level designs are becoming more and more auto-generated HDL and you just write C/C++ code for an embedded processor in the FPGA (either soft or hard). So knowing both has its advantages (at very least being able to read both).
Postby Bingo600 » Tue Nov 04, 2014 5:00 pm
Thank you for teking the time to overlook my ansvers , once again.
The course have been "just what i neded" in order to get started with real VHDL on real hardware.
And i have gotten some hands on in both the Quartus and the ISE world.
If anyone else want to get their hands "dirty" , and don't need the 5v tolerance.
Have a look@ebay or AliExpress for some nice offers.
My "best value for the money" is still this : Mini System Development Board ALTERA FPGA CycloneII EP2C5T144 for $13
http://www.ebay.com/itm/111242540701
The Max240 was almost the same price, but this one have many more resources , pull-up/downs , 2 PLL's and lot's of other goodies.
The development is the same as with a CPLD , with one extra step ... At the end you have to write the bitfile to the config eeprom on the board , if you want the design to survive a poweroff.
Most FPGA's don't have any built in flash/eeprom. And need to either read the bitfile from an external eeprom to FPGA Ram (done automaticly at powerup) , or have the bitfile programmed to FPGA Ram via jtag.
You'd use jtag during development , and save the final design into the config eeprom when the design is done.
Another bobus is that you don't have any flash wear issues like on a CPLD.
All i can say is : Try to take this course, if you need to get some hands on.
It's rewarding to see your first "blinky".
But if you're comming from a C background like me , don't mistake & for "and" ... It's actually the "concatenator" function in VHDL. "Think strcat() for std_logic vectors".
And make sure you read up on "Statemachines", if you want to do anything complicated like write to a LCD.
If Chris ever do a Part II , or a section 11..15 i'd love to get some better understanding of :
Synchronizing (flags) between processes. , and Statemachines.
Thanx for your time Chris :D
