http://www.pyroelectro.com/edu/fpga/parallel_hardware/
#7 Parallel Hardware [Post Homework Here]
Re: #7 Parallel Hardware [Post Homework Here]
Here is my homework
The logic flows are independant (as in per process), that makes all processes flow execute simoultainously (parallel)
This capability enables us to get a FPGA/CPLD to act as if it were many individual external "logic chips".
One process per "chip".
I had to be sure about the boolean expressions , and had to look up the operators + = "or" and * (or "Nothing") = "and"
http://www.doc.ic.ac.uk/~dfg/hardware/H ... ture01.pdf
I translate the requirements to be: A process where Y = (A or (B and C)) , and one where Z = (D or E or F)
This is my VHDL code.
And the RTL Viever
Crypto key breaking
Polygon drawing/shading (Graphics)
HighSpeed Communication / Interfacing (PCI Bus etc).
LED Controlling (Flatpanels etc.)
Here is my homework
What are some advantages of building CPLD hardware modules that operate in parallel?
Create a new CPLD project and build two combinatorial logic statements that operate in
parallel: Y = (A + BC) , Z = (D + E + F). Show the RTL viewer output to prove they will be
parallel statements.
use ieee.std_logic_unsigned.all;
entity lesson7a is
A,B,C: in std_logic;
Y: out std_logic;
D,E,F: in std_logic;
Z: out std_logic
end lesson7a;
architecture rtl of lesson7a is
BLK_0 : process(A,B,C)
Y <= (A or (B and C));
end process BLK_0;
BLK_1 : process(D,E,F)
Z <= (D or E or F);
end process BLK_1;
And the RTL Viever
In lesson 7 we gave an example of bit-coin mining, where a CPLD/FPGA would out-perform a
processor. Can you think of another example?
Crypto key breaking
Hi Bingo,
Correct answers!
I would add two simple comments
[Question 1]
We can even control process flow so that they can either both be serial or parallel with other processes. Like for example if we first divide down a clock frequency with a process and then use that slower clock signal to run another process.
[Question 2]
This can be done either in combinatorial logic or in a process, so it is a bit of a trick question. Since you chose the process route, I'll make a note that when you look at the RTL viewer it's also giving you sequential timing information with the ~0 and ~1. I tried to find the PDF on Altera's website that explains this in further detail, but no luck
Correct answers!
[Question 1]
[Question 2]
ThePyroElectro wrote:Hi Bingo,
Correct answers!
[Question 1]
[Question 2]
I did provide an implementation here of the lesson7 on the S3E board
viewtopic.php?f=26&t=832
I had hoped for a comment
