http://www.pyroelectro.com/edu/fpga/procedural_logic/
#5 Procedural Logic [Post Homework Here]
Re: #5 Procedural Logic [Post Homework Here]
Here is my homework
Combinatorial logic always runs.
Procedural logic runs when a signal on the sensitivity list changes.
To "trigger" the procedure.
Meaning that the procedural statements are only executed when one of the signals in the sensitivity list changes.
Here is my homework
What is the difference between combinatorial logic and procedural logic?
What is the purpose of using a ‘sensitivity list’ in a procedural logic process?
Using VHDL make a logic element with one clock input and one output. Then use procedural
logic to divide the clock input frequency by 4 and send it to the output.
entity lesson5a is
clk: in std_logic; --
clk_out: out std_logic --
end lesson5a;
architecture rtl of lesson5a is
signal f2: std_logic;
signal f4: std_logic;
DIV2: process(clk)
if rising_edge(clk) then
f2 <= not f2;
end if;
end process DIV2;
DIV4: process(f2)
if rising_edge(f2) then
f4 <= not f4;
end if;
end process DIV4;
clk_out <= f4;
Bingo600 wrote:Hi Chris
Here is my homeworkHOMEWORK QUESTION 1
Procedural logic runs when a signal on the sensitivity list changes.HOMEWORK QUESTION 2
Correct answers!
Thanks for showing the RTL viewer image as well. That thing really slams it in your face how two d-flip-flops is all you need.
