#4 Combinatorial Logic [Post Homework Here]
Postby ThePyroElectro » Thu Jul 17, 2014 8:14 pm
http://www.pyroelectro.com/edu/fpga/combinatorial_logic/
Re: #4 Combinatorial Logic [Post Homework Here]
Postby Bingo600 » Sat Jul 19, 2014 12:35 pm
Chris i'm in Sweden this weekend.
Will do the homework when i get home
/BIngo
Postby ThePyroElectro » Sun Jul 20, 2014 2:37 am
Bingo600 wrote:Chris i'm in Sweden this weekend.
/BIngo
No rush. Don't get stockholm syndrome :lol: .
Postby Bingo600 » Mon Jul 21, 2014 4:58 pm
Hi Chris here is my homework for lesson4
Name 5 combinatorial logic operators that you can use in VHDL.
AND,OR,XOR,NOT,NAND,NOR
Is it possible to implement all of the logic in a 74_08 (Quad 2-input AND Gate) logic IC inside
of our EPM3032A CPLD? (please explain why yes/no).
Yes it is
entity lesson4_7408 is
   -- Modelled after NXP 74F08
   -- http://www.nxp.com/documents/data_sheet/74F08.pdf
   D0a:    in std_logic;
   D0b:    in std_logic;
   Q0:      out std_logic;
   D1a:    in std_logic;
   D1b:    in std_logic;
   Q1:      out std_logic;
   D2a:    in std_logic;
   D2b:    in std_logic;
   Q2:      out std_logic;
   D3a:    in std_logic;
   D3b:    in std_logic;
   Q3:      out std_logic
end lesson4_7408;
architecture rtl of lesson4_7408 is
--Logic to implement a 74F08
   Q0 <= D0a AND D0b;
   Q1 <= D1a AND D1b;
   Q2 <= D2a AND D2b;
   Q3 <= D3a AND D3b;
RTL Viewer
Screenshot-RTL Viewer - -home-cfo-x-altera-pyro-course-lesson4-7408-lesson4-7408 - lesson4-7408.png
Screenshot-RTL Viewer - -home-cfo-x-altera-pyro-course-lesson4-7408-lesson4-7408 - lesson4-7408.png (52.51 KiB) Viewed 19564 times
Pretend A,B,C,D and Y are std_logic signals. Translate
This logic diagram to VHDL combinatorial logic.
entity lesson4_q3 is
   a:    in std_logic;
   b:    in std_logic;
   c:    in std_logic;
   d:    in std_logic;
   y:      out std_logic
end lesson4_q3;
architecture rtl of lesson4_q3 is
--Logic to implement a lesson4 question 3
   y <=  d NAND ((NOT c) or (a AND b));
RTL Viewer
Screenshot-RTL Viewer - -home-cfo-x-altera-pyro-course-lesson4_q3-lesson4_q3 - lesson4_q3.png
Screenshot-RTL Viewer - -home-cfo-x-altera-pyro-course-lesson4_q3-lesson4_q3 - lesson4_q3.png (44.71 KiB) Viewed 19564 times
Postby Bingo600 » Mon Jul 21, 2014 5:02 pm
Question 3 was a tough one.... :wink:
I had to grumble for a while :?
But just what i wanted to learn VHDL for.
I hope i got it correct , the RTL Viewer seems to inducate that i have.
Btw: I attacked the Logic "backwards , meaning the logic closest to the output was also written closest to the output assignment.
Does that matter ???
Postby ThePyroElectro » Tue Jul 22, 2014 3:35 pm
Bingo600 wrote:Hi Chris here is my homework for lesson4
All correct answers Bingo and admittedly more than I was expecting, well done! The RTL viewer is a very helpful feature as you seem to have already noticed.
Bingo600 wrote:Question 3 was a tough one.... :wink:
Yes you answered question 3 correctly. With logic personally I tend to separate the levels out vertically and attack it input to output. But you can surely use this method from either side to build up the combinatorial logic statement.
Postby Bingo600 » Tue Jul 22, 2014 4:30 pm
ThePyroElectro wrote: With logic personally I tend to separate the levels out vertically and attack it input to output. But you can surely use this method from either side to build up the combinatorial logic statement.
So the order doesn't matter : as in
and
y <= ((NOT c) or (a AND b)) NAND d;
Produces the same ?
I could try ,but i'd like a definitive ansver :wink:
Postby ThePyroElectro » Tue Jul 22, 2014 4:46 pm
and
Produces the same ?
Hi Bingo,
I only briefly mentioned it in the video, but in this case the order of operations comes into play since we are using parenthesis, statements inside parenthesis will be given precedence and executed first.
So yes, the order won't matter. Both should work.
A quick link about VHDL operator precedence:
http://www.csee.umbc.edu/portal/help/VHDL/operator.html
Highest precedence first, left to right within same precedence group, use parenthesis to control order.
So if you look at the precedence table you could actually write the combinatorial expression without any parenthesis. However personally I find the parenthesis useful when reading through my old code.
