#8 Design An LED Game [Post Homework Here]
Talk about the fourth PyroEDU course here.
Postby ThePyroElectro » Thu May 01, 2014 7:14 pm
http://www.pyroelectro.com/edu/microcontrollers/led_game/
little_cowboy
Re: #8 Design An LED Game [Post Homework Here]
Postby little_cowboy » Wed May 21, 2014 2:20 am
1. The trimpot acts as a voltage divider varying the voltage going to A0 from 0 to 5 volts, which A0 translates to a value between 0 and 1023. This value is divided by 4 to obtain a milliseconds value which is used as an argument in the delay function, timing the transition between LEDs.
2. The 4026 acts as a one digit counter/led segment driver. When pin 1 (clock) of the 4026 receives a pulse from pin D13 of the Atmel chip, it increments the count by 1.
3. The 10K resistor and the .1 ufd cap go from D3 to +5v instead of ground, leaving D3 high. The other leg of the pushbutton goes to ground instead of +5v so that when the button is pressed, D3 makes a transition from high to low, hence falling/
You also need to change the program line to:
attachInterrupt(1, winner_check, FALLING);
I thought this was a great lesson. Just for fun, I added a Serial.begin(9600); line to the setup section and in the main logic loop inserted Serial.println(analogRead(a0)); and Serialprintln(adc_val); lines so that I could turn on the serial monitor in the Arduino program editor and see the values change as I adjusted the trimpot while the program was running.
Postby ThePyroElectro » Fri May 30, 2014 5:09 pm
little_cowboy wrote:You also need to change the program line to:
Good answers!
The RISING/FALLING edge of the interrupt shouldn't technically matter since a button press will create both a falling and rising edge transition.
Nice addition to the program. I'm glad you liked the lesson!
Return to “Introduction to Microcontrollers”
