#6 Polling vs. Interrupts [Post Homework Here]
Talk about the fourth PyroEDU course here.
Postby ThePyroElectro » Thu Apr 17, 2014 4:15 pm
http://www.pyroelectro.com/edu/microcontrollers/polling_interrupts/
little_cowboy
Re: #6 Polling vs. Interrupts [Post Homework Here]
Postby little_cowboy » Sun Apr 20, 2014 10:14 pm
I'm was having problems with this lesson and was getting a solid HIGH at D13 when I initialized the sketch. The circuit diagram shows the high end of the pushbutton going to the TX pin. Although it's hard to tell from the video, it also seems to be that way on the breadboard.
In reviewing Arduino command reference for attachInterrupt, it referenced D2 as the pin that worked with Interrupt 0. So I moved the jumper from the pushbutton from TX to D2 and everything worked just fine.
Postby ThePyroElectro » Tue Apr 22, 2014 6:34 pm
little_cowboy wrote:I'm was having problems with this lesson and was getting a solid HIGH at D13 when I initialized the sketch. The circuit diagram shows the high end of the pushbutton going to the TX pin. Although it's hard to tell from the video, it also seems to be that way on the breadboard.
Thanks for the feedback!
I believe we made a mistake on the schematic. We'll update it to digital 2, which is interrupt 0.
wingsio
Postby wingsio » Wed Jul 19, 2017 8:52 am
Your article is detailed, thanks to it I solved the problem I am entangled. I will regularly follow your writers and visit this site daily.
wingsio
Return to “Introduction to Microcontrollers”
