#10 Schematics & Documentation [Post Homework Here]
Talk about the first PyroEDU course here.
Postby ThePyroElectro » Thu Dec 27, 2012 9:14 pm
The final lesson for this course was posted today!
http://www.pyroelectro.com/edu/basics/documentation/
coresnake
Re: #10 Schematics & Documentation [Post Homework Here]
Postby coresnake » Fri Dec 28, 2012 1:29 am
What is the difference between a datasheet and a schematic?
Datasheet - gives information about a specific part
Schematic - conveys the design of an entire circuit
What is the circuit symbol for a power supply?
http://www.clker.com/cliparts/5/8/5/5/11970907491735964845vermeil_IEC_Cell_Symbol.svg.med.png
Draw a circuit that connects a +5v power supply, resistor and LED together so that when
everything is connected, the LED will turn on.
http://i.imgur.com/lgP00.png
What information will you typically find on the first page of a datasheet for an electronic part?
Description of what its used for, summary of functionality, pin outs for different sized packages
Postby ThePyroElectro » Fri Dec 28, 2012 3:52 am
coresnake wrote:What is the difference between a datasheet and a schematic?
Good answers! Thanks for following along with this first course, we'll have the next course, An Introduction To Digital Electronics, live in March 2013.
I'll make one note about your circuit drawing for question 3, adding a reference marker to ground would make the circuit look prettier.
coresnake
Postby coresnake » Fri Dec 28, 2012 5:42 pm
Cool, thanks for the lessons so far. Can't wait for March!
jonnyquin
Postby jonnyquin » Sun Feb 17, 2013 2:36 am
Datasheet provides valuable information about an specific component and a schematic shows the actual lay out of a circuit
http://www.easyvectors.com/assets/image ... ip-art.jpg
Draw a circuit that connects a +5v power supply, resistor and LED together so that when everything is connected, the LED will turn on.
see attached document
HOMEWORK QUESTION 4
Name, model, make, characteristic parameters, pin numbers and functions, etc
circuito led pyro.png (12.83 KiB) Viewed 11790 times
Postby ThePyroElectro » Sun Feb 24, 2013 7:55 pm
jonnyquin wrote:HOMEWORK QUESTION 1
HOMEWORK QUESTION 4
All correct answers. Although I'll make a small point that its a good idea to add 'reference designators' or ways to identify parts on your schematic. So to your drawing I would add, V1, R1 and D1. In addition the value of the part is a good thing to have: +9v, 470 ohm, 5mm Red LED.
Hope you enjoyed this course! The Digital Course is coming in March 2013!
Return to “Introduction to Modern Electronics”
Users browsing this forum: No registered users and 55 guests
