CAN A MAX202 REPLACE A MAX233
MAC49
Postby MAC49 » Fri Apr 15, 2011 7:07 pm
8) hello everyone can i use a max202 in place of a max233 i would like to use this chip on the 18f452 to talk to a serial port also i have 10uf electrolytic capacitors to use on the max202 are these to large thanks for any help
Postby ThePyroElectro » Fri Apr 15, 2011 7:32 pm
The MAX202 will work for RS232 serial communication. Just make sure you wire it up correctly as seen on the datasheet:
Datasheet: http://datasheets.maxim-ic.com/en/ds/MAX200-MAX213.pdf
A +5v input is doubled to +10 by the Max202 for RS232 level outputs.
