The Sharpie Dotifier
pranita
Re: The Sharpie Dotifier
Postby pranita » Mon May 05, 2014 7:40 pm
what about their width?
Postby ThePyroElectro » Mon May 05, 2014 10:37 pm
pranita wrote:what about their width?
3.5 inch x 0.5 inch diameter.
pranita
Postby pranita » Tue May 06, 2014 6:23 pm
cant used variable diameter pen??? if yes what will be the range of diameter?
Postby ThePyroElectro » Tue May 06, 2014 7:56 pm
pranita wrote:cant used variable diameter pen??? if yes what will be the range of diameter?
Variable can work.
The parts list has the gripper linked to the distributor's website:
http://www.pyroelectro.com/parts/little_gripper/
The jaws open to 1.3" and the wrist rotates approximately 180 degrees. It needs only a screw driver for assembly. Use any of our Microcontrollers to operate the servos.
There is your diameter limit if you choose to use variable.
pranita
Postby pranita » Wed May 07, 2014 6:20 pm
thanx sir.... :)
pranita
Postby pranita » Tue Sep 02, 2014 6:35 am
u had used servo HS-5685 and HS-5485 i.e two different motors,for what purpose these two motors are used? plz mention the motor name n their work.
Postby ThePyroElectro » Mon Nov 03, 2014 12:03 am
pranita wrote:u had used servo HS-5685 and HS-5485 i.e two different motors,for what purpose these two motors are used? plz mention the motor name n their work.
HS-5685 gives you more torque and are better for the base/lower servo locations. HS-5485 is a little cheaper and less torque, better for the gripper/higher up servos.
Users browsing this forum: No registered users and 252 guests
