Categories
- animatronics (12)
- apple (11)
- arduino (179)
- art (41)
- articles (121)
- artificial intelligence (11)
- automation (421)
- avr (205)
- bitcoin (3)
- breadboard (9)
- cameras (57)
- cars (26)
- cell phones (28)
- clothing mods (21)
- console mods (26)
- dangerous (94)
- desktop mods (24)
- embedded (5)
- flying things (54)
- fpga (22)
- gaming creations (108)
- interface (225)
- internet (17)
- laptop mods (6)
- lasers (22)
- linux (7)
- magnetic (3)
- medical (12)
- microcontrollers (51)
- misc projects (152)
- msp (12)
- music (124)
- pic (90)
- projects (23)
- pyroedu (76)
- raspberry pi (26)
- robots (312)
- security (36)
- sensors (307)
- software (200)
- solar (19)
- stamp (9)
- tools (149)
- tutorials (98)
- Uncategorized (45)
- usb (44)
- wireless (256)
Sponsors
Build Like A Pyro!
Find many of the parts used on this site at our favorite online electronics shop
10 Amp H-Bridge For Motor Control
Posted May 20, 2011 by Chris
Today’s PyroElectro tutorial shows you how to build your own 10A DC motor controller on a PCB. The core design is kept simple so it is a great introductory project for hobbyists, while also shedding light on the basic method used for DC motor control. The parts cost less than $15 so why not give it a shot?
39 Responses to “10 Amp H-Bridge For Motor Control”
Leave a Reply
Currently Hot
DIY Animatronic Eyebrows
give your robot some emotion with animatronic eyebrows
Wireless Communication Over IR
ascii serial communication over infrared light streams
Dual Motor Control – SN754410
quick and cheap dual motor control of speed and direction
Wireless Motor Controller
easy wireless control of an led and a motor
Mini IR Theremin
make your own mini ir theremin
Animatronics
Recent Articles
Arduino DDS Shield
build your own arduino based analog signal generator
A Digital Multimeter In Review (Tenma 72-7735)
learn about your typical digital multimeter in review
The PIC Annoy PCB
build something to annoy your co-workers
Automate Your Life With Cron
learn how to use cron for computer automation
Web Scraping For Weather Updates
learn how to use php to scrape the web
Creating A Web Server In Linux
learn how to make a lamp web server in linux
Stepper Motor Control With A stepRocker TMCM-1110
learn how a commercial stepper motor controller works
Arduino To PIC Wireless Proximity Motor Control
control a motor with a distance sensor wirelessly
PIC to Arduino Wireless Communication via XBee
use xbee to make a pic wirelessly talk to an arduino
Motor Control via Infrared Distance Sensor
control a motor simply by waving your hand
May 22nd, 2011 at 6:02 pm
ik very good
January 21st, 2012 at 5:12 am
Thank you!
I just ordered the parts, and i look forward to it to have it work!
Mvg
Dave
March 19th, 2012 at 8:02 pm
uh, what about PWM, just send the output from the microcontroller to the circuit with no other circuit (safety circuit)?, will not be damaging the IC?
April 7th, 2012 at 2:52 am
where are the diodes for the kickback currents?
April 8th, 2012 at 3:36 pm
The flyback diodes are in your future design revision ;). This H-Bridge is meant to show you the basics of the basics, not for professional design. Enjoy!
April 27th, 2012 at 8:26 am
Respected Sir, I’d used this 4 H-Bridge on PIC16F84A it was work nice but when I was connected with 89v51rd2 its not working well making load cause problems as given below:
1) when 89v51rd2 start it goes all pins automatically high means both side transistor on instantly suffer short circuit.
2) This make output of 7805 voltage regulator 3.58V and hence all port pin low to 2.78V cause all H-Bridge start both direction at one time.
Finally my sir suggest me use a different 7812 voltage regulator for avoid a loading effect. I’ve used and now it’s working very well without heating a components. Thank you for providing such circuit and mainly “theory” its helps to clear our concept in electronics.
March 14th, 2013 at 11:26 am
Hallo will ein 12 volt motor über ein 5 volt servo steuern. Die position würde ùber den servo laufen kann ich eibfach die anschlüsse vom servomotor einfach an die h brücke anklemmen.
March 31st, 2013 at 9:56 pm
This is probally the best tutorial I’ve read on the net. Awsom job, very well done. I learned a lot. THANKS 🙂
May 4th, 2013 at 10:12 am
Thank you, I’ve recently been seeking for facts about this subject for ages and yours is the best I have found so far.
July 11th, 2013 at 11:42 pm
This technology is amazing.
November 10th, 2014 at 6:51 am
Where is the follow up video showing how to use PWM to control the speed?
June 22nd, 2018 at 1:08 am
rubber vagina
