Halloween - Need a way to move an animated mouth to sound
rbreak7
Postby rbreak7 » Fri Apr 15, 2011 3:17 pm
I am a beginner to alot of this. I am looking for an easy and cheap way to make an animated skull mouth move to inputted audio. Any help is greatly appreciated.
Postby ThePyroElectro » Fri Apr 15, 2011 6:06 pm
Hey rbreak7,
Well the easiest of easy would be to download MouthOff if you have an iPhone:
[youtube]http://www.youtube.com/watch?v=8wO3_5EbB9c[/youtube]
although I don't know how I would feel about leaving an iphone inside of a pumpking outside for a night.
Were you looking at trying to build some animated robot lips, or something along those lines?
rbreak7
Postby rbreak7 » Fri Apr 15, 2011 6:08 pm
Thanks for the app but I want to build an animated mouth fixture for a plastic skeleton head.
Postby ThePyroElectro » Fri Apr 15, 2011 6:31 pm
rbreak7,
To build a physical fixture, you would use a servo motor (or a motor type of your choice) to move the jaw back and forth. A microcontroller could control the jaw movement.
A servo motor is a type of motor that moves to and stays at a location you specify. The hobby servo in the tutorial below has a few spots for screws that you could mount the skeleton jaw too.
Servo Motor Control Tutorial: http://www.pyroelectro.com/tutorials/servo_motor/index.html
To make the jaw move with the audio, you would have two choices, either make it dynamically move with the audio [difficult] or input a bunch of known movements that the skeleton jaw would repeat [easier-but time consuming].
Maybe this gives you a intro to what you'd need. Hope it helps.
rbreak7
Postby rbreak7 » Fri Apr 15, 2011 6:33 pm
Thank you. I will go thru the tutorial. I want to try to do it dynamically.
Arthur
request for simple schematic
Postby Arthur » Sun May 08, 2011 7:01 pm
I like to do the same, where is sound (voice, song etc) input is converted to a movement of the jar (so the mentioned dynamic option).
Are any simple cirquits available?
Postby ThePyroElectro » Fri May 13, 2011 3:45 pm
Hi Arthur,
I'm not aware of any simple circuits as this is a pretty complex thing to do dynamically.
It would be easier and quicker in the long run to consider pre-programmed movements.
