#5 Passive Filters [Post Homework Here]
Talk about the third PyroEDU course here.
Postby ThePyroElectro » Fri Sep 27, 2013 5:21 pm
http://www.pyroelectro.com/edu/analog/passive_filters/
wr9h
Re: #5 Passive Filters [Post Homework Here]
Postby wr9h » Sun Nov 17, 2013 11:03 pm
Q3) Draw an RL high-pass filter circuit.
Note that the inductor is a low impedance path for low frequency signals (essentially a short circuit) and a high impedance path for high frequencies (acts like a high frequency open circuit).
Herb
wr9h
Postby wr9h » Sun Nov 17, 2013 11:12 pm
Used the wrong code for last upload :(
This is an RL high-pass filter. Note that the inductor is a low impedance path to ground for low frequencies (a short circuit) an a high impedance path for high frequencies (an open circuit). Essentially, the high frequencies have no where else to go but out to the output!!!
Herb
wr9h
Postby wr9h » Sun Nov 17, 2013 11:43 pm
Lesson 5 Passive RC and RL Filters
Q1) What is the cut off frequency, fc, of a filter and why is it important?
Short Answers:
fc is the frequency at which filter input frequencies will start undergoing alteration/attenuation (-3dB)
Importance: RC and RL filter design is predicated on the value of fc!!
Long Answers:
In a low-pass filter any frequencies below the fc, or cutoff frequency, are passed to the filter output without alteration or modification. Frequencies greater than the fc are altered and filtered out (passed to ground in an RC filter and "blocked" by the high frequency impedance of the inductor in an RL filter).
"Only frequencies less than the cutoff frequency will pass through the filter unchanged..."
In a high-pass filter any frequencies higher than fc will pass through the filter unchanged while those frequencies below fc will be altered and "filtered out".
Only those frequencies above the cutoff frequency will pass through the filter unchanged....
Herb
wr9h
Postby wr9h » Mon Nov 18, 2013 12:05 am
Lesson 5 RC and RL Passive Filters
Q2) Can a resistor+capacitor (RC) be used in both a low-pass AND a high-pass filter?
YES. The fc for an RC circuit is fc=1/2Pi(RC). This formula works for both low and high-pass RC filters?
How can this be? It's all in the resistor and capacitor arrangement and in how the capacitor behaves with applied AC frequencies. If the circuit is set-up with the capacitor across both the input and output of the circuit and there is a series resistor in the input circuit the filter is a low-pass. It works like this: the capacitor acts as a very high impedance to low AC frequencies so they cannot pass through the capacitor to ground (the common grounded lead of both the filters input and output). One might say that the capacitor "appears" as an open circuit to low frequencies. High frequencies pass through the capacitor and are "shorted" to ground thus "eliminated" from the filters output.
If the resistor is placed in the shunt position and the capacitor is placed directly in series between the filters input and output the filter is a high-pass filter. How does this work? The high frequencies are easily passed through the capacitor and the ease is directly related to the capacitor values; higher value capacitor pass higher frequencies (capacitors act as high frequency 'shorts"). Low frequencies see the capacitors as open circuits and are blocked.
Our experiment illustrated the above nicely:
With increasing capacitance the low-pass filter removed the high frequencies (passed them to ground).
With increasing capacitance in the high-pass filter low frequencies were blocked and high frequencies passed.
Very cool and fun experiment!
Herb
wr9h
Postby wr9h » Mon Nov 18, 2013 12:15 am
Lesson 5 Passive RC and RL Filters.
Low-pass RC circuit consisting of R=10 ohms and C=10uf, what is fc?
fc= 1/2Pi(RC)
fc= 1/(6.2831)(10)(10x10^-6)
fc= 1592Hz or 1.592kHz
Herb
Postby ThePyroElectro » Wed Jan 01, 2014 12:06 am
Glad to hear this.
The active filter experiment is even better in my opinion, keep at it!
Good homework answers as well.
Return to “Introduction to Analog Electronics”
