Alternative Parts
Talk about the third PyroEDU course here.
MerseyTrainz
Alternative Parts
Postby MerseyTrainz » Sat Sep 21, 2013 2:52 pm
I'm having trouble getting some of the parts over here in the UK.
Introduction to Analog Electronics
LM386 Audio OpAmp - Is there an alternative I can use?
Instead of using the 1N4138 - is a 1N4733A Zener Diode 500mW 5.1V OK?
Introduction to Digital Electronics
Instead of using the 4008 (is a 4008B - an alternative?)
Instead of using the 4026 (is a 4026BE - an alternative?)
Instead of using the 4511 (is a 4011B - an alternative?)
Best regards
Stephen Roberts
stepheneroberts1953@sky.com
Re: Alternative Parts
Postby ThePyroElectro » Mon Sep 23, 2013 7:22 pm
MerseyTrainz wrote:I'm having trouble getting some of the parts over here in the UK.
Best regards
Stephen Roberts
Hi Stephen,
1N4733A is the zener diode we actually use in the Analog Course, so that works. 1N4138 is a switching diode, which acts differently than a Zener diode so they aren't inter-changeable.
The parts you listed for the digital 4XXX series devices are all acceptable. However those 3 IC's aren't the most important part of the Digital Electronics course, you could definitely completely 95% of the material without them.
Hope this helps!
Return to “Introduction to Analog Electronics”
Users browsing this forum: No registered users and 4 guests
