#6 The Diode [Post Homework Here]
Talk about the first PyroEDU course here.
Postby ThePyroElectro » Thu Nov 29, 2012 8:24 pm
This week's course is now up and ready for you to watch:
http://www.pyroelectro.com/edu/basics/diode/
STLShawn
Re: The Diode [Post Homework Here]
Postby STLShawn » Mon Dec 03, 2012 12:27 am
What are some differences between an LED and a rectifier diode?
Which way does electrical current flow through a standard diode?
From Anode to Cathode.
What is the circuit symbol for an LED? for a standard diode?
OK, can’t post it in text, here’s a pic.
http://upload.wikimedia.org/wikipedia/c ... ol.svg.png
Diode
LED
HOMEWORK QUESTION 4
Which side of a diode component has a straight line marking, the cathode or anode? Why?
Straight line marks cathode side. A diode is single direction.
Postby ThePyroElectro » Tue Dec 04, 2012 6:06 am
STLShawn wrote:HOMEWORK QUESTION 1
Hi Shawn,
I didn't see an answer to #1, did you need some hints? Everything else was right!
If you're curious about 'other' types of diodes. Another more tricky type is called the Zener Diode:
http://en.wikipedia.org/wiki/Zener_diode
These are often used as small voltage regulators (keeping voltage steady) and also have a multitude of uses in RF/Analog circuits.
jonnyquin
Re: #6 The Diode [Post Homework Here]
Postby jonnyquin » Wed Feb 06, 2013 12:04 am
What are some differences between a LED and a rectifier diode?
LED emits light when conducting, whereas rectifier diode doesn’t emit.
LEDs are often used as light sources, and rectifier diodes are used in rectifying applications.
Materials used in rectifier diodes and LED’s have different properties.
From anode to cathode
This is the standard diode:
http://www.google.es/url?sa=i&rct=j&q=& ... 4878062658
This is a Led:
http://2.bp.blogspot.com/-rC1F8Ea4Qng/U ... symbol.png
HOMEWORK QUESTION 4
Cathode, because it is the negative side of the diode
Postby ThePyroElectro » Wed Feb 06, 2013 10:37 pm
jonnyquin wrote:HOMEWORK QUESTION 1
This is a Led:
HOMEWORK QUESTION 4
All your answers are correct. Good work!
JohnOO
Postby JohnOO » Mon Oct 27, 2014 10:23 pm
Hello there,
Sorry if this is the wrong place to post this, but I have had problems with the trim pot, it blew 2 LEDs on me while I was adjusting the screw in the first circuit experiment in the lesson video. Any advice on what I might have done wrong?
Postby ThePyroElectro » Sun Nov 02, 2014 11:43 pm
JohnOO wrote:Hello there,
Possibility [1] you are connecting the LED directly to power.
Possibility [2] the trim pot is at the lower resistance setting < 100Ω. After a few minutes at this setting it could damage the LED. If the trimpot is all the way down to 0Ω (meaning turned the knob the entire way) you will eventually damage the LED as it is almost completely connected to power.
If you're interested in learning about electronics, you might buy a bag of 1,000 LEDs off ebay for $15-20 and keep them in your tool box. Blowing LEDs out, while not ideal, can happen a lot when you're learning and prototyping.
JohnOO
Postby JohnOO » Mon Nov 03, 2014 8:19 pm
Thanks very much for the reply! :D
With possibility [2], I turned the trim pot partly towards 0Ω, and the LED died. Oh well, probably made a silly mistake without realising.
Thanks for the advice on buying bulk amounts of them, have already done so.
Return to “Introduction to Modern Electronics”
