#3 The Resistor [Post Homework Here]
Talk about the first PyroEDU course here.
Postby ThePyroElectro » Thu Nov 08, 2012 7:39 pm
The next lesson is up today and here:
http://www.pyroelectro.com/edu/basics/resistor/
ashraf2011
Re: The Resistor [Post Homework Here]
Postby ashraf2011 » Fri Nov 09, 2012 7:10 pm
[1]What is electrical resistance?
its an electrical unite describe the voltage that has to be applied to pass unity of current from point to another.
[2] What ‘Units’ are used to describe electrical resistance?
OHM'S
[3]Convert the value of 100,000Ω into Kilo-Ohm and Milliohm.
100,000 equals 100 kohm and equals 100,000,000 Milliohm
[4] Which would work better to connect a circuit together: Silver or Plastic? Why?
silver,its a sort of metal that has a conductivity and its resistance for current is low,but plastic has very large resistance
prevents any current to flow.
Postby ThePyroElectro » Sat Nov 10, 2012 7:03 pm
Good answers and All right!
I hope you were able to perform the insulators vs. conductors experiment. That is a very fundamental idea about resistors and electricity!
STLShawn
Postby STLShawn » Mon Nov 19, 2012 3:45 am
Resistors act like a funnel in an electrical circuit dropping the amps through resistance.
The Ohm (greek symbol omega) is the units of measure of resistance.
100 Kilo-Ohm = 100,000,000 Milliohm
HOMEWORK QUESTION 4
Silver, as plastic has a higher resistance than silver
karin91
Postby karin91 » Mon Dec 03, 2012 2:58 pm
its a measure of how strongly a material oppose current to flow.
OHM
100,000Ohm-100KOhm and 100,000Ohm-100,000,000 mOhm
Silver, because it have low electrical resistence.
Postby ThePyroElectro » Tue Dec 04, 2012 5:54 am
STLShawn wrote:HOMEWORK QUESTION 1
karin91 wrote:What is electrical resistance?
Hi Shawn, Karin,
All your answers are right, good work! I hope you followed the experiments in the video as well. One additional experiment you can do is turn your Digital Multi-Meter (DMM) to the Ω setting and check the different resistances of materials, metals, plastics, glass, clothes, play-dough, water, your hand..etc...
jonnyquin
Re: #3 The Resistor [Post Homework Here]
Postby jonnyquin » Fri Jan 25, 2013 1:25 am
It´s a force of opposition to the flow of electrons that a material posseses
The unit is Ohms(Ω)
100 kΩ and 100,000,000 Milliohms
HOMEWORK QUESTION 4
Silver, because it has got a smaller resistance
Postby ThePyroElectro » Fri Jan 25, 2013 9:40 pm
jonnyquin wrote:HOMEWORK QUESTION 1
The unit is Ohms(Ω)
HOMEWORK QUESTION 4
Hi Jonny,
All correct answers! Feel free to ask questions as you progress through the lessons.
HEGHELON
Postby HEGHELON » Thu Apr 04, 2013 9:05 pm
It´s a force of opposition to the flow of electrons that a material possesses
The unit is Ohms(Ω)
Convert the value of 100,000Ω into Kilo-Ohm and milliohm.
100 kΩ and 100,000,000 milliohm
HOMEWORK QUESTION 4
Silver, because it has less resistance
Postby ThePyroElectro » Tue Apr 09, 2013 7:15 pm
HEGHELON wrote:HOMEWORK QUESTION 1
The unit is Ohms(Ω)
HOMEWORK QUESTION 4
Heghelon,
All correct answers! Keep it up!
Return to “Introduction to Modern Electronics”
Users browsing this forum: No registered users and 4 guests
