The Sharpie Dotifier
Postby ThePyroElectro » Tue Dec 14, 2010 4:05 pm
Description:
The Sharpie Dotifier has limitations and strengths. It can draw stuff out using a sharpie pen and while it does make mistakes from jittery motion from time to time, overall it draws perfectly. However, the limitations do stand out. Not being able to draw a picture larger than 100x50 pixels, or to use more than 1 color seems almost ridiculous in this day and age. But! The Sharpie Dotifier wasn't meant to be cutting edge, rather to show how a robotic arm can be put to intelligent and useful work with some ingenuity.
Action Video:
pranita
Re: The Sharpie Dotifier
Postby pranita » Wed Feb 12, 2014 2:56 pm
Hello sir...
can u plz tell me the cost required for this project???? :D
Postby ThePyroElectro » Sat Feb 15, 2014 6:04 pm
pranita wrote:Hello sir...
Probably around USD$80-100.
pranita
Postby pranita » Thu Apr 10, 2014 4:01 pm
which software you used for this project???
pranita
Postby pranita » Sun Apr 13, 2014 6:17 am
for programming purpose which software you used?
Postby ThePyroElectro » Mon Apr 14, 2014 6:35 pm
pranita wrote:for programming purpose which software you used?
MPLAB from microchip.
pranita
Postby pranita » Thu Apr 17, 2014 7:52 pm
ok thanks sir... :) instead of PIC controller can we use another 1? and what is the reason behind using the PIC18F452??
Postby ThePyroElectro » Thu Apr 17, 2014 8:15 pm
pranita wrote:ok thanks sir... :) instead of PIC controller can we use another 1? and what is the reason behind using the PIC18F452??
Most of my projects used 18F452, that is why.
Another PIC could be used, but depending upon the series of PIC microcontroller, you may not be able to use the same code and C18 compiler that I used.
pranita
Postby pranita » Fri Apr 18, 2014 6:11 pm
okk... n how the paint file was converted into the command? i mean how the c++ scripting program wrote? n how it is converted into the .BMP file? 'BMP' stands for what?
Postby ThePyroElectro » Fri Apr 18, 2014 10:53 pm
pranita wrote:okk... n how the paint file was converted into the command? i mean how the c++ scripting program wrote? n how it is converted into the .BMP file? 'BMP' stands for what?
I drew the picture in paint and saved as a monochrome BMP. Then I wrote a C++ program to make a 2-d array out of the picture. And afterward the C++ program spit out commands in the form of a script that would tell the sharpie dotifier what servos to move and where.
pranita
Postby pranita » Sat Apr 19, 2014 6:28 pm
ok... is their is any another software used for this sending a command towards the pic controller??? RS232 used for interfacing purpose... but how the actual command send??
like when your going to work on 8051 controller,we program in KEIL software,n then hex file we are going to download on kit using 'flashmagic' software. so for this purpose what you had used??
pranita
Postby pranita » Sat Apr 19, 2014 6:39 pm
This project is gonig to make the dot of send pictute or text.. if i want to draw it continuously without dot, means same as that of sent message what should be changes ?? N if we use the choke instead of pen,for drawing diagrams on the board,then the servo n stepper requirement for project will increase???? simply my question is can i make this system for classroom board,if yes.. then what should be changes?
Postby ThePyroElectro » Tue Apr 22, 2014 6:46 pm
pranita wrote:This project is gonig to make the dot of send pictute or text.. if i want to draw it continuously without dot, means same as that of sent message what should be changes ?? N if we use the choke instead of pen,for drawing diagrams on the board,then the servo n stepper requirement for project will increase???? simply my question is can i make this system for classroom board,if yes.. then what should be changes?
Sorry, it is difficult for me to understand your questions.
To adapt this project for use on a school white-board would be very challenging given that this is a robot arm drawing with many degrees-of-freedom that must be navigated.
It would be wise to make something more like a 2-d plotter with motors to control the stage movement on X and Y-axis then a simple motor on the state to push a pen down and then back up to put the 'dot'.
Using a robot arm is much more than is required.
pranita
Postby pranita » Mon May 05, 2014 7:06 pm
the pen you had used is it variable???? what is the width of that pen?
Postby ThePyroElectro » Mon May 05, 2014 7:14 pm
pranita wrote:the pen you had used is it variable???? what is the width of that pen?
Not variable. Just a normal sharpie style felt pen.
These ones: http://pen.sharpie.com/
Users browsing this forum: No registered users and 255 guests
