Delays!?
Allibow
Delays!?
Postby Allibow » Sun Jun 07, 2009 9:07 pm
hello im having som problems, i have just started to program pic whit C
i have sucsessed to toggle the output for the LED on RB0 im using 18F4431
but when i try make it blinking it doesnt want to
i have tryed both delay_ms and delay_us
whit delay_us it starts to blink but its very random not as specified ....
#include <18f4431.h>
#device *=16 //activate 16-bit
// circuit checksum as ID
#ID CHECKSUM
// zero ram registers
#ZERO_RAM
// clock freq, (10mhz crystal)
#use DELAY(CLOCK=40000000)
// I/O handling
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
//ports to fileregister
#BYTE PORTD = 0xF83
#BYTE PORTC = 0xF82
#BYTE PORTB = 0xF81
#BYTE PORTA = 0xF80
        int iCount=0;
// PORTA all input 7pins
        SET_TRIS_A(0x7F); // 0111 1111 (1 is IN)
// PORTB all output 8pins
        SET_TRIS_B(0x00); // 0000 0000 (0 is out)
// PORTC declared output
// bit7 (RX) serial in serial port
        SET_TRIS_C(0x80);//1000 0000
      SET_TRIS_D(0xff);
// do while
        do{
            DELAY_US(500);
            BIT_SET(PORTB,0);
            DELAY_US(500);
            BIT_CLEAR(PORTB,0);
        }while(1);
}// END
Allibow
Postby Allibow » Tue Jun 09, 2009 8:18 am
turns out there was something wrong whit my crystal, it works when i change setting to HS instead of HS-pll
Users browsing this forum: No registered users and 7 guests
