configuring multiple A to D Ports with the pic 18f4520
Miguel Colmenares
Postby Miguel Colmenares » Sat Feb 07, 2009 2:59 am
Hi Chris, I'm tryining to read in values from 2 identical pot's using the A to D on ports A0 and E0. I'm getting a max decimal vaue of around 800 for port A0 and around 550 for port E0. These values should be the same and ive tried everythig from switching ports to varying delays between each A to D initialization. I'm thinking that im either exeeding the 10 bit register or not clearing the bits before each initialization. The pot values range from 0 to 671ohm. I would be greatful if you had any advice on the matter. Here is a sample of my A/D code below............
#include <adc.h>
#include <p18f4520.h>
int result1 = 0; // declare variable result
int result2 = 0; // declare variable result
TRISA = 0x01;
TRISC = 0x00;
while(1)
OpenADC(ADC_FOSC_32 & ADC_20_TAD & ADC_RIGHT_JUST, ADC_CH0 & ADC_INT_OFF & ADC_VREFPLUS_VDD & ADC_VREFMINUS_VSS, 0);
Delay10TCYx( 50 ); // Delay for 50TCY
ConvertADC(); // Start conversion
while( BusyADC() ); // Wait for completion
result1 = ReadADC(); // Read result
CloseADC(); // Disable A/D converter
OpenADC(ADC_FOSC_32 & ADC_20_TAD & ADC_RIGHT_JUST, ADC_CH5 & ADC_INT_OFF & ADC_VREFPLUS_VDD & ADC_VREFMINUS_VSS, 0);
result2 = ReadADC(); // Read result
Delay10TCYx( 50 );
Postby ThePyroElectro » Sat Feb 07, 2009 3:28 am
Hey Miguel,
A few things come to mind for this problem but my first thought is about your code.
I don't think the OpenADC function configures the TRISE bits so try configuring them properly for inputs on RE0, right now you only configure:
TRISA
TRISC
you'll also want to configure
TRISE
so that Channel 5 / AN5 / RE0 can be used as an input
Hopefully the solution is as simple as that.
Good to hear from you man! :D
andromilon3
Re: configuring multiple A to D Ports with the pic 18f4520
Postby andromilon3 » Sat Mar 07, 2015 7:37 am
Most importantly,I wanted to design a countdown timer that will activates the servo control code. I have been search the web for days but hardly find any that I can understand. I knew that I will have to use the clock or timer in the chip to generate this countdown timer. Certkiller 1z0-060
Is there anyone that can help? any code sample or tutorials will help, thanks.
