PyroPropeller Clock
saransound
PyroPropeller Clock
Postby saransound » Thu Dec 26, 2013 11:02 am
Hello , I want to know if the LED's have to be connected in an order to latch. The circuit shows 16 LEDs but i have used 13 LEDs so which latch do i fill up first. And how to wire the remaining 5 leds to the other latch.
Re: PyroPropeller Clock
Postby ThePyroElectro » Sun Mar 09, 2014 3:50 am
From the source code:
void set_leds(unsigned long int leds){
PORTA = 0x0F;
PORTC = 0xF0;
LED_LATCH_L = 1;
LED_LATCH_L = 0;
PORTA = leds & 0x0F;
PORTC = leds & 0xF0;
LED_LATCH_H = 1;
LED_LATCH_H = 0;
While the code will tell all 16 outputs to do something, I didn't actually use 16 LEDs because I ran out of space.
The closest LED to the middle will be Bit 0 of the Lower LED Latch enabled by PORTBbits.RB5.
The furthest LED from the middle will be Bit 7 of the Higher LED Latch enabled by PORTBbits.RB4
