need to make sure i set my micro controller up proporly
- Newbie Pyro
hi i need to make sure i set my micro controller up proporly it is not letting me upload code to it, and PIN D 13 is not flashing when powered up
- Attachments
- 12108066_10156083844710543_7394972574099953786_n.jpg (23.65 KiB) Viewed 24631 times
- Newbie Pyro
Re: need to make sure i set my micro controller up proporly
here is a another picture
- Attachments
- 12107817_10156083844775543_5023379511786783389_n.jpg (182.57 KiB) Viewed 24630 times
From the looks of it everything does look like it's connected properly.
Other things that could possible be causing the problem:
[1] Perhaps the TX/RX connections are swapped.
[2] Maybe the label on the Microcontroller is backwards? Does the notch on the Microcontroller line up with the black notch on the label?
[3] Maybe one of the jumper wires is bad?
I'll look through the photos again, if you have something higher quality that perhaps you could upload to imgur or wherever that could be more helpful.
::EDIT::
I don't see the +9v connector going to the 7805 Input + Ground. Are you powering your circuit another way? Does the power LED turn on?
::EDIT::
- Newbie Pyro
i just don't have the battery plunged in for the picture but the red led turns on but the one on pin d13 won't blink, i also checked the label and it is on right also the RX is in the TX and the TX is in the RX like it is suppose to be, can we conclude that the micro controller is bad ?
RinoScremin wrote:i just don't have the battery plunged in for the picture but the red led turns on but the one on pin d13 won't blink, i also checked the label and it is on right also the RX is in the TX and the TX is in the RX like it is suppose to be, can we conclude that the micro controller is bad ?
Ok, great. When you plug in the USB to your computer you can find out what port it is using on windows by looking in the control panel -> device manager -> PORTS & LPT. Make sure to set the Arduino to talk over that port.
Do the Tx or Rx LEDs on the USB-to-Serial board light up when you attempt to program the microcontroller?
Another possibility is that the push-button is connected incorrectly and shorting the reset pin 1 to ground. Does the pin 13 led start blinking if you remove the push-button?
I'm slowly running out of ideas and unfortunately I don't have access to a micro controller kit until Friday (moving locations). But I can try to reproduce the problem you're seeing then and get back to you.
- Newbie Pyro
after removing the switch the LED still will not blink the and the RX/TX LED blinks on the usb when attempting upload to the micro controller and the ardiuno is talking to the wright port, i don't think its a problem with the IDE cuz i tried it on two different computers
RinoScremin wrote:after removing the switch the LED still will not blink the and the RX/TX LED blinks on the usb when attempting upload to the micro controller and the ardiuno is talking to the wright port, i don't think its a problem with the IDE cuz i tried it on two different computers
I do apologize for the difficulty you are having. In most cases students are able to build the basic microcontroller circuit up and get going right away, so consider yourself unique
It sounds like the USB-to-Serial converter is doing its job correctly with the Arduino IDE, so I can only recommend to double check (with a multimeter) the VCC/Reset pins are getting +5v and the GND pins are getting 0v (-- hold down the reset button...does the LED blink program run then?...maybe you wired it in backwards?). If you setup the circuit with power, grounds and reset connected and that LED off digital pin 13 doesn't blink, then I might say either the IC burned out (over-voltage or ESD) or the microcontroller's bootloader wasn't correctly installed.
As I mentioned before, the soonest I can get my hands on some hardware to help you out is Friday. I hate to keep you waiting that long but the gods demand it! In the mean time, alternative explanations of the circuit used in lesson 2 of the microcontrollers course can be found here:
[1] Breadboard Arduino on Instructables
[2] Breadboard Arduino on official website (this one doesn't have an auto-matic reset during programming so you have to manually press the reset button when the Arduino IDE starts uploading to the microcontroller)
Users browsing this forum: No registered users and 3 guests
